Valve Cover
    Valve Cover
    My valve cover screws keep coming lose... I just replaced the gaskets... Oil also keeps getting into the spark plug cylinder... How can I fix this problem. This is the 2nd time this has happen to me.
    Thanks,
    Javier
    Haven't heard of that happening before, are they torqued correctly? 7 ft lbs each
    If they keep coming undone, I'd put some non permanent threadlocker on them.
      did you use hi temp silocone?
      miss my turbo cb7
        Originally posted by accordaffair
        Haven't heard of that happening before, or they torqued correctly? 7 ft lbs each
        Make sure they are torqued evenly. If it isnt poil will still get in the plug tubes.
          Did you overtorque them? The head is aluminum, and the threads are very easily stripped. If that's the case, you'll have to re-tap, or replace the head!
          Maybe pull the cover and make sure the gaskets are all seated properly. If you're pinching one, it'll cause problems. If you ARE pinching one, replace it with a new one.
            x2 i had this problem before and it was stripped head.
              x3 same here.
              Facebook.
              Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
              Member Ride
