if oil is on the threads(not electrod) of your plugs is that bad...
oil thread
oil thread
Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishockTags: None
It means you need new valve seals which should come in the valve cover set. And oil pops in usually when you unscrew and the oil drains into the combustion chamber and around the threads.
No..not valve seals. What he needs are rocker assembly orings. But I get what you are saying Nail. Get a valve cover gasket set from the parts store and replace the lower spark plug tube seals under the rocker assembly. the oil in your spark plug tubes will eventually cause stumbling acceleration and misfire from the oil interfering with the plug wires.Originally posted by NAiL05It means you need new valve seals which should come in the valve cover set. And oil pops in usually when you unscrew and the oil drains into the combustion chamber and around the threads.
Here read.
http://www.cb7tuner.com/vbb/showthread.php?t=87820
so what i need to get are the rocker assembly orings... or valve cover gasket set and replace the lower spark plug tube seals UNDER the rocker assembly...does the set come with the orings... how long would this job take to do
and your dead on about the stumbling acceleration... would that cause the bat light to come on... i have had the bat checked its fine and all the charging stuff is fine as well
i was thinking timing
No..not valve seals. What he needs are rocker assembly orings. But I get what you are saying Nail. Get a valve cover gasket set from the parts store and replace the lower spark plug tube seals under the rocker assembly. the oil in your spark plug tubes will eventually cause stumbling acceleration and misfire from the oil interfering with the plug wires.Accord SE
93se
Members Ride
