Ok, we been through this many times. But here we go again. I wanna do the H22 head swap on to my F22A1, that valve cover just looks too sexy to pass up! Here are my question(s) though.
-Other then the hondabond i need to use, are there any head modifications i need to make for the DOHC to properly fit on the block?
-The H22, will i need the Intake manifold for the H22, or is there one that is better that i can get?
-When i put everything in, and i got the head bolted onto the block, im told that i need to run wires to the VTECH Solenoid, but where do those wires go to, the ECU?
- How much HP and throttle responce am i apparent to have after the head swap?
-When swapping over the H22, do i need a different fuel pump then the one that i have currently, or is it good enough?
-After swapping the H22, will my exhaust header i just purchased off ebay work with that head, or will i need to purchase a new exhaust 4-2-1 header?
-Will the S2000 Throttle body work on the H22 head?
-When i convert to the H22, Do i use the H22 spec timing belt, or is there a specific belt i need?
Knowing that my F22 block is still in great condition, is it a smart move to put it on this motor? ( I have 260XXXkms on it as of now) I tested it when i got it at 210 PSI each cylinder as well. Going to retest on the weekend.. thats all i can think of right now though.
Thanks!
Thanks!
) with 260k miles??? nope. but thats my opinion only.
