yeah let me know if it works i hope for ur sake it does it took me a lot of time and money to fix the free prob 10 min job lol.and yeah my teacher used an example of the exact same thing the other day and i was like for a jke was it an accord lol. and he was like yes actually a 91 then i laughed and noticed this must happen often enough.
After driving brakes lock up what can it be??
Autozone only does OBD-II or newer (least the ones I've been to). I haven't found anyone with a scanner for pre-OBD-II, do they even exist? lol
So why did you have that much break work done to begin with?
You could disconnect the power booster and see if the problem goes away. Though obviously don't go far from home or too fast
I'm not aware how much the effect the booster has.
How are the wheel bearings? How do you know it is in fact the brakes? Just trying to go in a different direction if the ABS check doesn't turn up anything.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
bad news guys the day i was going to get my car fix that same night car got stolennnnnnnnn but God will punish who did that to me but good news is i found my car since they couuldnt go so far cuz like i said car locks up after driven for more then 15 mins so i ended up findind it thank God intact but yes i dunno if i sould just sell the dam thing i need to get a killswitch cuz cop was going to arrest me cuz no signs of break in in the car or ignition ...like if the had a spare is there a such thing as a master key cuz i only have 1 key and no one ever touch my keys.......
I have seen a flex hose go bad, what seemed all at once. After changing pads on a GM product. The caliper on one side would drag then drag real bad then lock up. The problem turned out to be the flex hose it was swelling from the INSIDE acting like a check valve and holding pressure. The fluid would go through the hose under pressure, then NOT come back through the hose. This was holding pressure in the caliper, we changed the hose and the issue was solved. This may not be the problem but this can happen, best of luck.
man i have the same problem alltho ive removed my ABS and now just my fronts are locking up i got new calipers front and rear and my breaks keep locking up over a short drive....im thinkin its the booster my self which im gunna change here soon ill keep ya'll updatedOut of a job yet? Keep encouraging people to buy American. 500 of the biggest, most profitable American companies make more than half of their profits overseas! You Jackass!
