clutch problems
    clutch problems
    i recently did my own clutch job...now i hear a squeaking noise. it will go away when i press the clutch. i have a good idea what it is...pressure plate bolt loose?
    i didnt set to specified torque or use threadlock
    everyone agree ??
    that could b it or it could b the throw out bearing. did u grease the shaft b4 u put the bearing on?
      ya i greased it, not too much just a little. i hope i got that spring thing in properly. o yea i should have stated that there was no noise for the first 300 miles and then i got that noise all the sudden
        mine on my sedan squeaks like when your pressing it in
        but i guess it's fine on mine as long as it runs
        Me with your Mother
          Sounds to me like the throwout bearing. IS the sound like a high pitch chirping sound? If so, thats prolly what the sound is.
          97 Yamaha YZF600R
          Vouches: wagalude/sleepycb7/accordexr33/yeamans17/heylookitsdylan/tommi/JDMH22ACB7/smokeeey420/sackingz123/
          IDriveALude/Losiracer2/626cb7
            does it make the noise when the clutch isnt depressed, but when you press the clutch it goes away? If so both of my CBs do this, so i think its fine.
            Well not fine, i read that it was the top n bottom bearing on your tranny. Here let me go get a link from H-T. Im not sure if this is it or not
            HT Link
            ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
            NE GUYS, Buy the last of my accord parts
              If it was TO bearing it would be pretty consistent and a constant hum. You probably didnt grease something enough. That was what was wrong with my old trans when I pulled it off. It was squeaking when I depressed it looked at the shaft and it was dry as hell. It would squeak but everything else engaged just fine.
                mine makes a high pitched squeeking noie as well..i go under the hood and it was coming from the clutch...if u press ur foot down lightly on the clutch does it stop? mine does and i was told its fine, just in the long run dont be surprised if it goes...
                  found this thread in search so if figured id ask to see if you resovled the problem cause im having the same problem with my clutch, it only squeaks when i dont have the clutch pushed in. and ive put on brand new clutch, pressure plate, slave cylinder, and master cylinder. and it didnt do it till about 300 so miles after i put it together.
                  If at first you don't suceed, then skydiving is not for you.
                  I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
                    If it's not the throw out bearing sliding on the nub of the tranny, it could be the pivot ball for the release fork. After that, sometimes the pressure plate itself will make a small amount of noise, from what I've witnessed in the past.
