Ok here we go. I started having problems with my car not wanting to start after I fill it up with gas, so I thought it was something to do with the fuel pump. Tested it and there was nothing wrong with it. Then I noticed I could not hear the pump turn on when I turned the key to the on position so I thought it might be the fuel pump main relay. I could here the relay click when I turned the key but did not hear the pump come on so I replaced it anyway. Still nothing. So after about 30min of turning the key on off on off on off the pump finely cam on and I attempted to start the car. It sounded like one cylinder fired and then quit. So I checked the distributor to see if everything in there was good. Every thing checked out. This is about to drive me insane. When the pump comes on I have good pressure I have spark the injectors resistor is in good shape around 5-7 ohm. Got any ideas what the problem is
1993 CB7 LX
F22A1
1993 CB7 LX
F22A1
. I don't think it is the pump though. i will check it again your way anyways. thanks
