did you check spark man? because if your not sparking and your pump wont work when you turn your ignition on.... pop your hood..... go find the ground that goes to the thermostat mount on the left side of the engine, by your intake... its just a bolt on ground... IT TOOK ME 3 DAYS after my Head swap, to figure out why in the hek i was getting no spark, no fuel pump.... etc. I was upset. even if you havnt been messing around under the hood.... check it out for corossion? good luck man
CB will not start
if u have to turn it over so many times.... u might wanna check ur starter too. can't rule that out cuz i had to turn the key several times on mine to get it to runOriginally posted by vh22accordi replaced the relay already and and still have the problem. i did get it to start last night however and it ran great but as soon as i turned it off it went back to the same ol thingMember's Ride Thread
Bought From: AccordWarrior | CB7lx91 | DarkShadow707| Tn_Accords | H23CB7 | Jack_lee | Fatboy1185Originally posted by deevergoteDon't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
I agree. Maybe you got some bad gas, or something in the gas clogged your fuel filter. Have you checked out the filter yet? Might be worth it before you dump a wad of cash into a fuel pump.Originally posted by onefastbunnyi think it would most likely be a fuel related issue if it only started happening since you filled it that time
I am not having trouble out of the starter It works just fine . I think it is a fuel issue I just cant seem to put my finger on the problem. I put a new fuel filter on this morning and that was not the problem . I also did a compression check to see if maybe the head gasket was blown . Not that either
IT IS WHAT IT IS
I checked Fuel injector resistor. See this is the funny thing I checked just about everything related to the fuel and the ignition system and every thing is good. All my grounds are good. I have one more question …… could low amperage from the battery be causing the problem. I’m getting 12+ volts out if it but I think the amps are low. What do you guys think.
IT IS WHAT IT IS
