dsm 450 injectors
    dsm 450 injectors
    would it be back to run my car without the turbo with the injectors in. or would it just backfire.
    it back fire, bog, and probably blow something. if you got some dsm injectors sell them.
    miss my turbo cb7
      so in other words only run them with the turbo
        yup.
        miss my turbo cb7
          There's NO reason to run larger injectors without significant mods (like turbo, a big shot of nitrous, supercharger, or a wild NA build)
            you might be able to get away with running bigger injectors if u throw in a bigger cam and and upgrade your entire intake. a cai or sri wont cut it in that sense.
              that still it to much. n/a cars dont run anything over 350cc.
              miss my turbo cb7
                I think he goin turbo later but he wants the injectors on first. You can put them on no harm will be done other than dumping an abnormal amount of fuel in the chamber. The DSM is 2x the CC of the f22a injectors. If you can chip your p06 and alter the map you can run the 450cc on your car.
                  With a chipped ECU & Tune you could run the 450's. It would be a waste of 210cc's but it will run. The 450's would probably be running @ approx 55% duty cycle to match the flow rates of the stock 240cc injectors.
                  I wouldn't suggest running them without a tuned EMS / chipped & tuned ECU. I would just wait until you get your turbo. You will see little to no gains running 450's on a stock motor.
                  MR Thread
                  GhostAccord 2.4L Blog
                  by Chappy, on Flickr
                    Injectors are quick and easy to swap out, for the most part. Get the injectors, stick them on a shelf, and wait until you have all your turbo parts.
                      x2.
                      miss my turbo cb7
                        i never really specified a size... all i was stating is that if he did a serious overhaul on his intake he could get away with goin bigger.
                          ...what the hell...
                            you told me "i might get away with having bigger injectors if i have a moddified cam and build intake mani."
                            and i told you that still to much (of fuel). you have to understand that you dont need much fuel to run a car. the less fuel you use and the more air you have, the faster the car is.
                            cams and moddified intake manifolds have nothing to do with fuel ratio. thats all about air ratio. getting more air into the cylinders. the fuel system is the fuel ratio. the less fuel the more air the better the explosion.
                            miss my turbo cb7
                              WoW!!! can you say DETONATION!
                              Have you ever heard the saying "You can't have one without the other" that's why they call it AFR (Air to Fuel Ratio) The amount of air you add directly influences the amount of fuel you need to add. So yes your cam and intake do have a lot to do with your fuel ratio.
                              You are planning on running a Turbo correct. You do realize that they are a heat making machine....hope you have some plans to run water injection to keep your lean AFR engine from melting.
                              MR Thread
