h22 swap front mount problem
    hey i have a 92 accord lx that im swapping a jdm h22a in. everything ive read says to reuse the front accord mount and its a direct fit or what not. but it seems the front accord mount is not lining up with the mount location on the engine. the accord front mount appears too long and it sits further up above the mount location on the h22. so some people say i dont need to use the front mount but id rather use it if i can. does anyone know of any possible reasons this is happening or if anyone is running their swap without a front mount. is it alright to drive it without the mount?
    you must use the accord bracket as well.
    i would not run with the front mount unless all your other mounts a solid or filled
    Members Ride
      It was a tight fit on mine. i had to put it in 1st gear then rock the car back and forth while pushing on the bolt to get it in the hole. Not the best way to do it but it worked.
      ALL PARTS MUST GO
      http://www.cb7tuner.com/vbb/showthread.php?t=157038
      Link to my turbobuild/members ride
      http://www.cb7tuner.com/vbb/showthread.php?t=110483
        My front mount fits fine... but the shop that did my swap used the Prelude tranny mount, and did a hack job of it. I suppose everything sits fine, but I'm only running 2 studs on the tranny mount! I guess that means my setup doesn't really apply to this situation...
          did you get your H22 leveled correctly?
          Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
          ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
          ...this thread has been graced by the new CB7 King
            yea from the the looks of everything its all level and we did the tranny mount successfully with the new studs and what not. the front mount actually is straight inline with the mount on the engine but it just sits too high above the spot to bolt to the h22. the car is in a friends garage and i cant remember if he tried the accord bracket, might have to double check that.
              has the car ever been wrecked....there may have been some hidden frontend damage
              I didnt notice issues with mine until I pulled the engine out
                nope never been wrecked or damaged. ill need to check if the accord bracket is being used. that may be my problem.
                  how far off is it from lining up?
                  ALL PARTS MUST GO
                    ill have to check tonight or tommrow on exactly how much. i havent seen it yet im just going off what my friend told me when he wasnt putting in the h22. from what he said its like an inch or two above the bracket on the h22. i dont know if he tried the accord bracket or not . i assume that he would have but ill have to ask.
                      ok from what it looks like the mount is just too tall. it looks like the mount needs to be way shorter, it needs to be like a couple of inches shorter.
                        jack up your motor, thats what i did for my front mount too.
                        Vouches:accord93racer, 93twodoorLX(twice), kmart64, deevergote, 92cord, Datmofo, DarkShadow707,slammed4thgen
                        Old MR Thread
                        1996 Prelude SE- Project
                        1996 Lexus SC300-Daily
                          ^^ Yep. Jack it up a little. When you remove bolt for the mount, even on F22, the engine falls some.
                          My swap thread
                          Main relay proplems?--DIY
                            cool so like jack it up with all the other mounts attached?
                              i got a h22 sWAP, and everything is going fine and dandy so far.
                              ----------------------------------I ♥ My CB7----------------------------------
