drivers door stuck shut
    i have a 93 cb7 sedan the drivers door won't open i have taken apart the door panel and all levers are moving correctly i believe the latch that holds the metal cylinder on the inside of ur door jam is stuck closed . to replace the latch u have to have the door open any ideas on how to remove old latch from inside. drilling dremeling (ripping out )
    ''COUPE''
    ''WAGON''
    http://www.cb7tuner.com/vbb/showthread.php?t=52477
    later.
    Avoiding dirt at all costs
      door broken
      I have the same problem with my 90 sedan. How did u get the door panel off if the door is still shut? i have the same question on this forum take a look at what everybody's saying. good luck! If u find out how to open the door will u drop the answer here?
        Take out the seat. It will give you more room to work.
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
