Can someone tell me where all the vacum lines go and which ones need to be plugged up on a H22a? (its in a 92 cb coupe, lx)
H22 vacum lines?
all the vaccums holes are pretty much the same.Hook up the vaccum holes as u would a F22.THe only things is that some vaccums lines might be at different locations on a H22 then a F22.When i hook minds up, i hook up everything i would a F22, but i use the map senor from the F22 rather the H22. BUT everthing should be the same for the most part. JUst look at the manual for an H22 and u should be fine.
