no spark on 2nd cylinder
    The cap and rotor for a 90-91 Accord will work fine.
    If you're not getting spark to just one cylinder, there's a problem with either the cap, wire, or plug. All easily replaced. Replace each, one at a time, and see what fixes it. That's really all it could be.
    The ignitor would most likely cause no spark to any cylinder, as would the coil. Those are also good things to replace. Again, 90-91 Accord parts will do the trick.
      ok thanks for the usefull info! ill prolly go with a 90-91 cap & rotor. so just making sure, the 90-91 accord is internal coil? i know my 92 accord f22 was external.
