so im a die hard cb7 lover. but DAMN these can look good are there any binifit of a cd5 over a cb7? (as in availability of parts, easier to swap, ect. ? )
diffrence
Newer cars.
Crappier engines (aside from 5 extra horsepower over their bone stock CB counterparts)
An actual SiR model with an H22... but never sold in the US, so that means nothing to us.
Different looks... some prefer the appearance of the CD to the CB.
The tuner world took to the CD more seriously than the CB, earlier on, anyway... so there are a few more options for the CD that aren't there for the CB.
The suspensions are very similar.
The main deciding factor is the way they look, and the age. One isn't considerably better than the other, especially when you're dealing with cars that have swapped or boosted engines.Last edited by ACC0RD22; 10-09-2010, 11:45 AM.
94-95 CD5 EX all day over CB7.
750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
I prefer the CD for the progressive body lines that still look good to this day. The CB is too boxy for me. Both are great cars.1994 Honda Accord SiR Sports Sedan
“When I do good, I feel good; when I do bad, I feel bad, and that is my religion.” - Abraham Lincoln
CD5Tuner - A Fifth Generation Accord Community
PS3 tag: Mechtroop
Both look good imo but i like my shoe box CB7, dont know if the weight is any diffrent but the CD5 look twice as heavy (but im pretty sure its about the same)
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
A CD weighs a couple hundred pounds more than a comparable CB, but otherwise they are really the same car. I've seen a CD described as a CB in a dress, and its pretty accurate. I like the interior of the CD more, and I'm a bit biased on the exterior being that I own a 97. Both drive extremely well, I think the CD has a longer wheelbase (because it has a longer wheelbase than most cars), which will make it a little less nimble but more settled feeling.
They generally take the same suspension parts, engine swaps. CB's are probably built better, but CD's are screwed together pretty well too (both better than most new cars). It really comes down to if you like the way they look. Oh, and the F22Bx motors aren't as good as the F22A's. If you are swapping, this is not a concern.
the economy honda motors(D and F series) that were built after 95 were not built to the same standard as previous years for cost reasons
the crank as two oiling holes on 95 and earlier, and from 96 on they only have one hole and it is not on the correct side of the crank
the holes are on the bottom of the crank when the combustion stroke is happening instead of on the top of the crank were it will lubricate the rod bearings when the most force being applied
I hadn't heard this. Maybe this is why so many F22Bx motors eat rod bearings and have knocks?Originally posted by quaidum View Postthe crank as two oiling holes on 95 and earlier, and from 96 on they only have one hole and it is not on the correct side of the crank
I will state that an F22B2 will survive a long time with no bearing left on one of the rod journals, and under 10psi of oil pressure at idle.
