manual trans remote starter
    Originally posted by slick
    they sell a neutral safety switch for the viper alarms so you cannot start your car in a gear. its the only way to make sure your safe
    did no one see that the sell a safety switch that will only start if its in neutral
    Maple50175 - you're annoying =P
      well I guessi will see when im finish installing it since yall say that the manual trans remote start have to be hooked up to the parking brake. mine does have a turbo timer on it and I will let yall know the outcome when I finish to see if I had a problem or not thank for the help people.
      honda life 4218
        I'm prety sure they work the same way....parking brake on, engine running, key out, door open, then closed, THEN engine off.
        If door opens before remote start, remote start is overridden until sequence is repeated.
        You can't leave it in gear (car is running), and someone can't put it in gear, and have the remote start work (door switch disables the RS).
        All the ones that say "my boi had his start in gear..." didn't have the correct remote start equipment.
        2003 Maxima SE Titanium Edition
        1993 Suzuki GSX1100F 136bhp
          yea I believe they all work the same I will let u know the info soon
          honda life 4218
            warning....my friend had remote start on his integra 5 speed, until he remote started the car and it ran into his garage door....i wish i had video of that
            sold to: bootlegcb7, jhondayaaj
            bought from : b3nsonx , *JDM_CB7*, bmxicansd, konig52r,
            Slick_Nine, CB7_213
              Someidiot was driving his toyota truck around in 4-Hi with the starter
              He got it into second and was going pretty fast for a starter say 15mph
              Your man for wiring solutions!
              CB7Man's Coupe H22 Swap
              CB7Man's Sedan Resurrected From The Dead
                Originally posted by UrDoneSRH
                it doesnt have to turn on but for a few seconds to do it.
                my buddy had a remote in his pocket, leaned on something and activated the remote start sending the car into a wall. his boss had moved the car and left it in gear. you can be as careful as you want, but someone else could fuck your shit up quick.
                i will only do it on cars with turbo timers, they have to be put in nuetral.
                this is a prime example of why i dont let no one drive my car.
                honda life 4218
                  im not saying that there is no ways of accomplishing it. im not saying you cant do it. and im not saying that theres 1000s of people who have remote starts on manual transmissions.
                  im just stating that its not safe, that is all. if you have a manual transmission specific remote start then congratulations on doing it the right way. but sensors fail, door triggers fail ... shit does happen.
                  Member Ride Facebook
                  XBOX LIVE = RedDragonsFool
                  SOLD MY CB JUNE 16, 2009
                  For Sale Thread
                    There is only one way.
                      that's understandable I respect your concern toward the situation.
                      honda life 4218
                        well i thought it was for manual trans but it wasn't that was a different model alarm but this model i have comes with a built-in turbo timer :-), but to get to the point i finished my project "remote start"..lol. i had the service manual where it told me the clutch switch was a pink wire when it really was a purple/black wire but it's ok i got it *wink*
                        honda life 4218
                          yeah now we just have to remind him every nite when he gets home to make sure he leaves it out of gear especially when he been drinking that nite
                          "IT IS WHAT IT IS"
                          new look courtesy steelbluesleepR
                            To All Those With Worry
                            Simple Tap Into The Clutch Wires And Put A Switch Simple On/off Switch For The Bypass..........just Make Sure That Ur Car Is Not In Gear Ok ......ok ....another Safe Precaution U Can Also Use Is A Mecury Switch For Shutting Off In Cause Durring Cranking That The Car Should Move....the Mercury Swith Is And Ball With Metal Moves And Alarm Shuts Off ........................................that Mecury Switch Then Is Taped Into The Shut Off For The Remote Start Wire Usually Is The Brake Pedal Wire.....
                            Most Remote Starts/ Alarm Need A Some Wires To Tap Into The Car
                            turn the key,Clutch-Gear-Gas ..Gone.... R.B.
                              in my z i made a plate around the shifter with a bunch of reed strips...which activate when a magnet is near.
                              i jbwelded 4 earth magnets to the shifter stick...this way if its in gear it turns on one of the reed switches telling the car not to start. worked flawlessly.
                              also you can purhcase the 698m from dei which is a manual transmission start thing where it goes though a sequence.
                              also as for bypassing the clutch you dont have to. find the wire on the alarm that is "ground when remote start" and its usually a blue wire and it sends a ground to wahtever device you are hookign up. simply tag that to the switched side of the clutch pedal wire...
                              everytime it remote starts the wire sends a ground and thus completling the circuit for the clutch to operate. also it will still work normall if you try and start the car with the key (you still have to push the pedal down).
                              Retro!
                              Hater
                                lol eventually you will mess up and start it into something
                                stop being cheap and get this ---) dei 689m
