I had my alarm installed and the would not hook up the remote starter cuz my car is a 5 speed.so today i hooked it up my self and it dont work!! even if im in the carholding the clutch down.has any one done this before that can help thanx.i cant find what i should do with the neutral safty switch either.
viper alarm 791 starter install "help"
My guess would be that the alarm requires the neutral safety switch to be activated so that it thinks the car is in neutral. Try pressing the switch and using the remote start. Is it a switch or just a wire?
My 5.7 LS1 Holden Ute
did u hook up the relay =)
i forgot, tpham knows...he installed hella alarmsWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Connect the neutral safety switch wire to any ground.
You can either use relays to interupt the clutch signals if you want to do it properly and so it still works as it should or if you don't give a rats ass about cruise control or about needing to depress the clutch to start then you could just jumper the upper switch.
