Sub + OEM Head Unit ???
    Okay, i just bought a polkAudio of 360watt rms... Now i need an amp, not a big problem, but the thing is that a have an oem radio with a oem honda cdplayer connected to it... And i love the oem look. Is there a way that i can connect the amp to the radio?
    The best option
    Honest, the best option if you want to retain a stock look is to get a unit similar to the JL Audio clean sweep.
    You can read more about them here
    There are cheaper ways to do it, and you can find them at Wallmart, but I would still suggest something like I posted above, because I enjoy sound quality.
    Hope this helps.
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
      Hope this helps.
      So what does the sleansweep do? and how much does it costs ?
        pretty much all you need is a LOC (line out converter) which takes the signal from your speaker wires and convert them into RCA's that you can use with your amp.
        this is how i have it set up. but without a LOC i just made a makeshift RCA and cut them...but it won't be as clear or hit as hard if you just spend the money on a LOC.
        and wire your remote wire to the antenna and the amp will turn on. without wiring up to the front to the HU
        Yes my name is Dang, Don't use in vain
        1992 Honda Accord EX (Coupe/Bordeaux/Auto)
        1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
        2008 Honda Accord EXL (Coupe/SanMarino/6spd)
          Looks like you know a lot, may you help me?
          Cause i try to find the best way to save money... So if i understand, i take the rear speaker wires and plug them in the amp. From there, i run wire to the sub and 2 other wires to left and right speaker ?
            Rockfordfosgate's 3sixty.1 will hookup your OEM and give you options for RCA amp hookup
              well ill say...
              I recommend one of these...
              http://www.crutchfield.com/p_142SLC4...4.html?tp=2001
              Now u can go and spend a few houndred one one a processor unit spoke of above.
              But I reccomend one of these because since your running a sub, and as long as the amp has a low pass filter then ur system will be set...
              Since your using the oem head unit that only pushes 7 watts rms a channel I dnt think sq is a huge factor here. So that line level converter will be great for this application. It's even a four channel, so if u wanted in the future u could amp your whole system.
              It's your choice what u want. But if your using sub 100$ speakers and less than 40 watts of power than, using a processor isnt gonna make a diffrance vs a line level converter. Since your main speakers will distort long before sub woofer signal quality becomes an issue.
              Even if we were dealing with highs it might make a diffrance and thats a really big might. Since were dealing with low frequinceys plus the fact that it's gonna get muddied up sence it's gotta go through a seat and back deck. So... There would be no audible diffrance.
              My System
              http://www.cb7tuner.com/vbb/showthread.php?t=165155
