ok so, I just recieved my viper 5701 alarm, and in the install manual thier are 7 types of door locks they are:
Type A: Three-wire (+) pulse controlling factory lock relays.
Type B: Three-wire (-) pulse controlling factory lock relays.
Type C: Direct-wired reversing-polarity switches. The switches are wired directly
to the motors. This type of system has no factory relays.
Type D: Adding one or more aftermarket actuators. These include central locking
systems without an actuator in the driver’s door, but with factory actuators in
all the other doors.
Type E: Electrically-activated vacuum systems.
Type F: One-wire system - cut to lock, ground to unlock.
This is a very rare system found mainly in early 90’s imports and some newer
Hyundais.
Type G: Positive (+) multiplex. One wire controls lock and unlock using
resistor(s).
Type H: Negative (-) multiplex. Same as Type G system, but uses (-) pulse
instead.
Note: You can use a 456L door lock learn module for Type G and H, instead of
relays and resistors.
im trying to find out which one our cars use, i know its not A or B since those are both pulse type locks, well at least im pretty sure its not either, and ive installed a cheapo door lock system on my other accord 5 years ago but never knew which type it used, but this one i need to know because it affects how i install the alarm, so anyone know?
thanks
Hyundais.
resistor(s).
instead.
thanks
