Originally posted by wed3k
View Post
Redline Water Wetter
Originally posted by customchord View PostI've used water in the summer for the past couple of years. I've never had a problem with it and don't use in the winter. Thats why I said to flush it in the winter. And no I don't live in the middle of the dessert. Max temp is 100 in the summer around here and my needle reads 1/3 the way max. Know if I sit and let it idle for 20 minutes the fan will kick on a bring it back down but have never had problems using water.
Losiracer2 have you tried using a colder thermostat or taking the thermostat out so the coolant is flowing the minute you start the car?
okay i'm gonna add this stuff tonight w/ just plain ol' distilled water. I highly doubt that I'd need the antifreeze for a long while, so just water and WW it is. It says on the bottle: 228 for 50/50 antifreeze, 220 for 50/50 + WW, 220 for water only, and 200 for Water + WW. So that seems the best option for my area. It says it also lowers cylinder head temps by 20* so that's always good.
For the guys that have used this...do you think it improves gas mileage since the engine runs cooler?
also you guys dumped the entire bottle in right? I'm not sure about the coolant capacity, it says like 1 ounce per quart so i'm pretty sure we have more than 12 quarts right? or is it less?
okay found out its 4 qts for drain and fill and 7.5 qts for filling from dryLast edited by Losiracer2; 06-23-2008, 10:25 PM.
Originally posted by customchord View PostJust use water, it has alot better cooling propertys than coolant. Just remember to drain and fill will coolant before winter.
& Ive used that redline stuff. I didnt really notice a difference
93 Accord LX Sedan (sold)
Originally posted by F22HB View PostThis stuff?
Dexcool is great. I run it in my civic and we run it in all our racecars.**Blk Housed Slut Crew Member #1**
Originally posted by Losiracer2 View Postokay i'm gonna add this stuff tonight w/ just plain ol' distilled water. I highly doubt that I'd need the antifreeze for a long while, so just water and WW it is. It says on the bottle: 228 for 50/50 antifreeze, 220 for 50/50 + WW, 220 for water only, and 200 for Water + WW. So that seems the best option for my area. It says it also lowers cylinder head temps by 20* so that's always good.
Ya man just dump the whole bitchin it... Make sure your system is bled propperly and you WILL notice a difference, those who dont must be looking at an OEM gauge or some shit... 15-20 degrees is a good bit of sweep on any reputable gauge...750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
Originally posted by C91BLX7 View PostYou want it to be in the middle.
It should be about 1/3 the way up not 1/2 (which is what Im assuming you meant by "in the middle").
I guess you could have meant in the middle of the first half... but that would be a incorrect assumption im assuming... Get it???
LOL750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
well I'm already noticing a difference. The temp gauge doesn't go above 1/2 at all, and its a blistering 114*F again today. So this additive was definitely worth it!
Originally posted by Losiracer2 View Postwell I'm already noticing a difference. The temp gauge doesn't go above 1/2 at all, and its a blistering 114*F again today. So this additive was definitely worth it!
Yup... Shit works....750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
I used redline watter wetter once, and it didn't do anything. It's hot out, and you will just have to get used to it. It was in the 80's at ocean the other day.
Originally posted by foamypirate View PostMj is correct. The makeup of antifreeze raises the boiling point of the liquid in the cooling system from 212 to around 224*. That can mean the difference between cooling your car with liquid, or cooling it with steam.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by F20A CB7 View PostI'm changin my rad and my car always reads in the middle for the temp2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
