So whats up with these cams?? i remember a little over two years ago it seemed the Delta 272 Regrind was hott now i never hear anything about em?? is there a better one out now??
Delta cams??
Delta cams??
R.I.P. Landon Hilburn 06-27-08
Soon to enter the family.
CG Coupe!
92 Accord EX Sedan (Newest project)
Members ride thread 92 EX Sedan
Members ride thread old 91 LX CoupeTags: None
yea like what all you reccomend for upgrades to go along with the cam?? especially in a H23??R.I.P. Landon Hilburn 06-27-08
CG Coupe!
Your asking what to do with reground cams on an H23? Honestly the IM is pretty nice on those so the only thing I could think of would be a good header. After that it should be a good flowing motor. You'll most likely need somthing to compensate for the cam though. Either an afc or a chipped ecu.
no like i wouldn't have to upgrade or buy new valves or such?? like nothing headwise??Originally posted by F22HB View PostYour asking what to do with reground cams on an H23? Honestly the IM is pretty nice on those so the only thing I could think of would be a good header. After that it should be a good flowing motor. You'll most likely need somthing to compensate for the cam though. Either an afc or a chipped ecu.R.I.P. Landon Hilburn 06-27-08
CG Coupe!
damn 282?? whats the biggest that you can do?? 272 is the highest i have heard ofR.I.P. Landon Hilburn 06-27-08
CG Coupe!
Honestly, I would stay away from Delta and go with Crower for H23 cams if you want real performance for your motor. I believe even Bisimoto sells cams for this application as well. If you stick with the lower level cams from both of these supplier, you will more than likely be able to retain the stock valvetrain. I agree on the better header suggestion as well and retained the stock intake system would be fine. You would need some engine management to get the most out of the cams.
Delta are generic cams not designed for the motor. Yes, they will improve over stock, but their powerband is not catered/designed for the motor.
oh ok well see i plan on buying it before my motor goes out anyway and like lightly build it a little before i throw it inOriginally posted by HondaFan81 View PostHonestly, I would stay away from Delta and go with Crower for H23 cams if you want real performance for your motor. I believe even Bisimoto sells cams for this application as well. If you stick with the lower level cams from both of these supplier, you will more than likely be able to retain the stock valvetrain. I agree on the better header suggestion as well and retained the stock intake system would be fine. You would need some engine management to get the most out of the cams.
Delta are generic cams not designed for the motor. Yes, they will improve over stock, but their powerband is not catered/designed for the motor.R.I.P. Landon Hilburn 06-27-08
CG Coupe!
how much we talkin?R.I.P. Landon Hilburn 06-27-08
CG Coupe!
can these cams be put in the f22a1 ... if so whats the results? how much?Originally posted by dbsharp View PostI plan on getting a better cam from bisimoto before it is all said and done. I will sell you my h23 delta 272 when that time comes, if you want it.The local asshole, 19 years in the making and still not giving a shit
Originally posted by mj213Wait... don't you have a carbon fiber hood? You need to give your "bro" a cunt punt.
Originally posted by bizzyboiHe will defend his stance on raping his car to no end.
