OMG!!! muffler noise help
    I replace my down pipe and header and I am running 2.5 catback all the way back with a magnaflow resnonator and magnaflow muffler (single 2 1/4" in)- dual(2" out) and this crap is loud as hell when I about around 2000 rpms and more ...I need to tone is bad boy way too... any sugguests to bring the noise level way down.
    PS....staight pipe, no cat
    HELPPPPPPPPPPPPPPPPP
    New paint job and bumper 8/8/11
    tsx retrofit
    f22b dohc boosted
    custom gauges pods
    Motivation is one of the keys to life....tell me "can't" and I wll show you I can
    You say you are running a cat, and then mention something after the cat converter...but then you say you have no cat, and it's a straight pipe?
    What do you ACTUALLY have?
      ok....straight pipe in place of the cat...2.5 at the end of the straight pipe all the way back...magnaflow resonator and muffer included
      tsx retrofit
      f22b dohc boosted
      custom gauges pods
        Aside from Schrödinger's cat, adding a second resonator will help, you could also remove the muffler and add stainless steel wool to the intake side (used to do this back in the day, but be advised, it will add a little restriction). Chore boy works great, just stuff some in there and try it until you find an sound/performance ratio you're comfortable with.
          would it be better to replace the straight pipe with a cat or just a short resononator
          tsx retrofit
          f22b dohc boosted
          custom gauges pods
            Either would help.
              high flow cat and a second resonator
              no
              Accord turbo kit under $2k here
              $30 HID kits here Thread
              "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
              "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
                why not get a silencer that goes to your tip of your muffler you can make one but idk, you need a stainless steel plate good size enough for your muffler tip, and screw three or two holes in your muffler to hold up the silencer, i did this to mine cuz my Carbon fiber muffler has a loud deep tone, and with the intake installed it sreams deep!!!!...but with the silencer it sound like a normal noise level but you still get your same tone of noise....
                .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
                  on a stock setup...high flow cat won't benefit you, waste of money. If you are turbo or built engine then a WELL BUILT high flow is best...cheapos are a waste of money.
                  You NEED the cat, a resonator, and a long big muffler to quiet down.
                  check the muffler bearings too
                  ____
                    i find magnaflows to be very loud. id invest in a big chambered muffler.
                    I <3 G60.
                      Ditch that straight pipe and get a cat. I got my exhaust off eBay, had the "test pipe" on it, it was loud as shit, put the stock cat back on, its way quieter, sounds like stock exhaust, even with a fart can for a muffler. But I still get the benefit of having 2.25 inch exhaust with a header. The ONLY time it's loud is if I down shift, then its a nice, deep tone
                        alright cool...stock cat it is...I was hoping someone had an answer like this one...
                        tsx retrofit
                        f22b dohc boosted
                        custom gauges pods
                          alright problem solved but I learned the hard way..the cat is on and I remove the magnaflow muffler and went back to my dynomax turbo muffler...quiet as hell now
                          thanks for your help fellars
                          tsx retrofit
                          f22b dohc boosted
                          custom gauges pods
                            with no resonator or aftermarket resonator will still be loud though i mean louder than the stock being there.
                            Originally posted by toycar
                            Braking the bank, maybe. Feeling like a boss, likely.
