ebay hi flow cat
    ebay hi flow cat
    i think i might be looking in the wrong place but i know there was a thread bout the ebay hi flow cats. but i cant find it. and if there wasnt what do you guys think?
    OBX
    http://cgi.ebay.com/ebaymotors/OBX-H...spagenameZWDVW
    http://cgi.ebay.com/ebaymotors/90-93...spagenameZWDVW
    or random off brand
    im leaning towards the first one because i want to run a 2.5in exhaust. but i might end up doing 2.25in so idk. i dont have the exhaust yet tho im just putting it together peice by piece.
    input???
    The stock cat supposedly flows well enough that it isn't worth buying an ebay cat.
      oh really. hmmm. well what is the intake and outlet size for the stock cat?
        get this: http://cgi.ebay.com/ebaymotors/MAGNA...4506.m20.l1116
          from what I have seen, the ebay cats dont have any catylist inside them. They are just test pipes called cats.
          1990 accord Honda-Challenge, H22 powered
          newer race video,older race videos
          1991 accord parked, parts and back up shell
          1993 accord acquired 6-11-16
            i took a look at my exhaust today for the first time. discovered that the shop used a catback piece for my exhaust then welded the whole thing together. so im going to need a cat at one point.
              it's more like a resonator
                I would personally go with a Catco High Flow cat if you were going to do that. But to be honest, a high flow cat or test pipe even will not give you much of a HP gain. Maybe 1hp...not worth the cost IMO.
                VIP Status.
                  ok well my current setup was pieced together by the what was laying around the shop when they fixed my car. so if i dont go catback then i will need to get a new cat. and i figure i might as well get a hi flow one while im at it.
                    Originally posted by Losiracer2 View Post
                    x2 on that, I got similar but with out flanges will weld them my self, eather way get hight flow converter should give you 3 more hp's, dont get test pipe.
                    magnaflow FTW:thumbsup
                      i had the obx high flow cat on both my accords, and i loved the difference in sound they made. so thats my vote.
                      "Self Renewed"
                        unless you have turbo or EXTENSIVE n/a mods (like bisi's build or hondafan's white accord) you don't need a high flow.
                        Do NOT buy cheap high flow or you will not pass emissions...it should be larger than a stock one by far...longer and/or wider...otherwise you're wasting your money.
                        But really you don't need one, the stock one won't significantly inhibit your hp, increase your exhaust tubing to 2.25" an you'll get a better effect than a high flow cat.
                        But again, they aren't cheap and if you find a cheap one, avoid it because you will be buying a worthless hunk of metal
                        ____
                          To the guy that said a high flow will give you 3hp. I call bs on that. You'd be lucky to see 1hp with a stock motor with simple bolt ones I/H/E. I doubt you'd even see 15hp total from I/H/E on a stock F22...even an H22. You'd maybe see 3hp if you had extensive work done on the car, otherwise don't waste your money.
                          VIP Status.
