H23 performance
    Wow that torque is nice. Why is the rpms down I thought that the stage 3 would rev a little higher than that?
    "The Turtle"
    DD/Trail Rig/Mud Bug
      Originally posted by 93F22A6 View Post
      200hp is just a goal, I'll prob end up with something around 180ish. This is the list I have so far.
      H23 (duh):750
      H23 Crower stage 3 race:430
      Bisi H23 cam gears:260
      Arias 12:1 comp pistons:595
      Crower rods:750
      So yeah it's won't be the cheapest build but it will be a one of a kind build. Plus that doesn'tcover all the little stuff like the tb bore out, injectors, tune, water pump, timing belt, etc. I'm trying to do as much research as possible. Going to start this in the spring since i'll be working at a machine shop and i'll have access to a flow bench and other good stuff i don't have at home.
      You are forgetting all kinds of stuff required for a build, such as seals, gaskets, bearings, rings etc. Add those in and you will be above what an H22 would cost.
        Originally posted by preludeman92 View Post
        He actually used an f23 block, crank, and rods. He bored bored the block 1mm and used h22 pistons. He had to machine the head a little to make it all work, but flow wise, the head and intake manifold are stock.
        Actually, Pirate drives that car on the street alot, even with stage 3 stuff. He says it idles fine at 950rpm
        Here are his dynos:
        Green is build with stock h23 cams
        Blue is Build with h23 head/crower 3 cams
        Red is build with f22b head/crwoer 3 cams
        H22 with bolt ons vs G23 build:
        Red is H22A
        Blue is Build
        I'm actually in the middle of a build similar to what he's done. I'm changing a few parts though... Bisi Stage 2 cams (this is what Bisi recommended), k24z3 pistons, blacktrax manifold, mildly ported head (mostly on the exhaust), 68mm TB. My goal is 200whp and 190wtq... the tuner thinks this is easily possible if I get a better exhaust system. To think, the entire block is stock honda parts and I get 11:1 compression and 2306cc's and it all fits together correctly... almost like honda intended it.
        If you intend to put Arias forged pistons in the h23 block you'll have to do your homework. As far as I know, the h23 has FRM walls, and FRM walls don't like forged pistons.
        Mahle makes forged pistons that are compatible with the stock FRM walls. They can be found under the "gold series."
          I know thats why I put ", etc." I didn't feel like adding up all the stuff right now. It might cost more than an H22 but if you build the H22 your going to spend money too. Yes i know if you build an H22 you can make alot more power than an H23 build.
          "The Turtle"
            horsepower sells... you DRIVE torque.
            i peronally own/drive an AUTO jdm f22b w/ a worked bottom end and easily hang(some i beat, some i lose to) h22s all day. this is on a completely STOCK head and comletely stock auto trans.
            if you mean 200 CRANK hp, easily do-able...
            THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
            My Ride thread
            Flickr
            Originally posted by d112crzy
            And it can only get better. That's the best part.
            All I gotta really say is:
            People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
              The f23 rod bolts are tiny and h22 pistons are pretty heavy, so he chose not to rev higher than where the power peak happened at 6500 rpm. Reving higher just didn't gain anything on this setup. I'm sure with a little cam tuning and some more air flow this setup would continue to make power past 6500rpm if you had the balls to rev that high.
