How hard is. it to install cams? Is there a how to somewhere? On a h22a. Should I have a pro do it? They r skunk stage 1 only
installing cams?
It depends on how skilled you are. It shouldn't be to hard for the average home mechanic. The only diy I can think of is in a hanes manual or similar. Just basically remove the vc, remove tension on the timing belt, unbolt cams retainers, and go from there. You have to adjust the valves as well to, and transfer cam sprockets unless you have a spare set or bought new ones from SK2.
"The Turtle"
DD/Trail Rig/Mud Bug
I searched on here but found nothing detailed enough, so I google searched it and came up with this, hope it helps:
http://www.honda-tech.com/showthread.php?t=1857587
1992 Honda Accord Coupe LX
its easy as cake as long as you have an auto tensioner retainer( you can buy one at honda for $13)
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
if you can do a valve adjustment and have a torque wrench, then you can install some cams.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
yeah man its not bad at all i did a cam in my f22 its basicly the same i would belive for an H22 i just followed my haynes book the only thing i didnt do is replace the timing belt and i really should have, im kicking my self for it but i took my time and it took me 2 days after work which was probley about 4 hours each day or so. but go for it! its the best when you do it your self
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..
