These are my plans!
1st-find an H22a1 running or not. <--Done
2nd-build it from bottom to top for street use and reliablilty!<--Block and head done.
3rd-Barred and Reffed smog legal.
Heres my plans for the motor,
BLOCK
-Stock H22 crank polished<--Done]
-New honda main/Rod bearings<--Done
-Eagle H beam rods <--done
-Mahle Gold series pistons 11.5-1CR (no block sleeving)<--Done
-BLOCK ASSEMBLED!!!!
HEAD
-BC stage2 or sknk2 pro2 cams
-Bisimoto cam gears
-Supertech valve springs & TI retainers<-Done
-Ferrea high comp. valves<-Done
-Supertech valve stem seals<--Done
-Bronze valve guides<-Done
-Valve job and resurface<-Done
-street port n polish<-Done
-Custom ported/gutted intake Mani.<-Done
-Phearable.net 70mm throttle body
-Cometic head gasket done
-arp head studs done
-HEAD is done and on the block!
DRIVE TRAIN
-M2F4 Tranny<--Have it
-Clutch masters stage 2+
-ACT 12lb fly wheel <--Have it
- LSD
INTAKE/EXHAUST
-Try-Y header 2.5" collector
-Apexi ws2 muffler
-Kteller 3" cat back
-3" intake piping carb legal hopefully
BRAINS/IGNITION
-phearable.net chipped ecu
-Have it dyno tuned
-MSD blaster coil<--Have it
-NGK wires/plugs
Gaskets/new parts
-OEM honda gaskets
-Water pump done
-Kazienspeed mani tensioner<--Done
-New oil pan done
-New T stat done
-all new belts
-New fluids
Im missin a few things but this is what im starting with, anything to add or if their are better things i should switch out just lemme know.
im excited
BLOCK
HEAD
-Bisimoto cam gears
DRIVE TRAIN
- LSD
INTAKE/EXHAUST
-Apexi ws2 muffler
BRAINS/IGNITION
-Have it dyno tuned
-NGK wires/plugs
Gaskets/new parts
-OEM honda gaskets
-Water pump done
-New oil pan done
-New T stat done
-all new belts
-New fluids
im excited
and i worked my ass off to get it this far and im gunna finish it lol
