not bad consdering this is pretty much stock. get a 260 cam on this bitch and more air and it should move.
My 1991 Accord dyno results
Originally posted by wed3k View Postnot bad consdering this is pretty much stock. get a 260 cam on this bitch and more air and it should move.
My little girl
1991 CB7 Accord EX
F22A4 with P12 ECU on the stock four-speed automatic
K&N E-0774 air filter in place of airbox
NGK Iridium IX spark plugs
Sony CDX GT640UI head unit
6.5" 2-way Alpine Type S up front
6x9's 3-way Alpine Type S in back
MTX Terminator 600W peak 50W RMS 4-channel amp
Originally posted by otacon122 View PostI was thinking a SRI, 2.25" exhaust, and Bisimoto L2 cam.
Originally posted by otacon122 View PostThat ain't a trick - that's the torque converter lockup clutch engaging. It supposedly engages twice on these cars, as the automatics are labelled "four channel, two lockup" automatic transmissions, which may mean four gears with the lockup clutch engaging twice. Also, if I read the transmission design info correctly on the internet, it appears as if the automatics in these CB7s are basically manual transmissions with a torque converter in place of the clutch and a stator plate is used to shift the gears - these automatics are not planetary gearsets like the rest of them are. These ones are designed like a manual with three shafts that mount four forward gears and a single reverse gear, using a stator plate powered by hydraulic pressure to shift gears - the first shaft is the drive shaft, which is powered by the crankshaft through the torque converter and has a single gear on it that powers all the other gears. The two remaining shafts both mount the four forward and one reverse gears and both are connected to a limited-slip differential that powers both front wheels at the same time. That also explains why these cars are able to hold their position on slight inclines with no brake pressure.
1990 Accord LX Sedan~Sold
1993 Accord EX Sedan~Sold
1995 Suzuki GSX-R 750~Totaled
Originally posted by otacon122 View PostThat ain't a trick - that's the torque converter lockup clutch engaging. It supposedly engages twice on these cars, as the automatics are labelled "four channel, two lockup" automatic transmissions, which may mean four gears with the lockup clutch engaging twice. Also, if I read the transmission design info correctly on the internet, it appears as if the automatics in these CB7s are basically manual transmissions with a torque converter in place of the clutch and a stator plate is used to shift the gears - these automatics are not planetary gearsets like the rest of them are. These ones are designed like a manual with three shafts that mount four forward gears and a single reverse gear, using a stator plate powered by hydraulic pressure to shift gears - the first shaft is the drive shaft, which is powered by the crankshaft through the torque converter and has a single gear on it that powers all the other gears. The two remaining shafts both mount the four forward and one reverse gears and both are connected to a limited-slip differential that powers both front wheels at the same time. That also explains why these cars are able to hold their position on slight inclines with no brake pressure.91 LX Under Construction. http://www.cb7tuner.com/vbb/showthre...00#post2017900
Originally posted by wed3k View Posteven better. what about header?
By the way, my goal with the car is autosound competitions, not performance. I have a Sony head unit, two Sony Xplod 6.5's up front, two Sony 6x9's in back, and its all powered by an MTX Terminator 4-channel outputting 45W RMS. All four speakers are three-ways.Last edited by otacon122; 05-01-2009, 01:14 PM.
My little girl
1991 CB7 Accord EX
