1 step colder plugs
    Originally posted by gdout90accord
    and i already put it on my car, would it be still fine MIDNITE?
    You already know my answer to that
      i got the ZFR5FIX-11, i mite have to go back to oriely check if its right.
      so i guess its not fine? midnite? haha
        I'm going to answer for him. It's not worth it to risk it over a $6-7 set of plugs man. Just be patient and do it right.
          yea yall were rite the zfr6fix-11 is 1 step colder, did yall buy the irridium plugs? or just the regular plugs that cost like 1.99 a piece?
            the regular ones
              o0o does it matter if i got the irridium plugs?
                Nope they're just a waste of money IMO...they'll work the same tho
                  hahah its all good now i know. aite thanks
                    Originally posted by midnite racer x
                    benefits? disadvantages running 2 steps colder?
                    If the plug is too cold there is risk of fouling during extended periods of idling and low-speed operation.
                    Colder doesn't mean better, you want to find the sweet spot between fouling at low temp / speed and pre-ignition at high temp / speed. Inspect your old plugs when you take them out, they'll tell you a lot about what's happening in there and if you need a colder / hotter plug. Obviously if you're running turbo / nitrous you're going to go colder for sure...
                    I've said enough.
                      I've said enough.
                      no actually that was very beneficial...kinda explains why my car keeps shutting off at idle lol
                        that's why the box say "high rpm's", when you're at high rpm's the temp are too high in the plug and they could make a spark before the right time that's why it's good a set of cold plug's.
                        Razer.-
                        Rev rev rev
                          Hey would it hurt to run 1 step colder plugs when your not under boost/nitrous??? i'm selling my nitrous but i still have the 1 degree colder plugs?
                          HAN - ZiviCase10287
                          Honda-tech - zivicase
                          HMT - draztik
                          d-series - draztik
                          Team Integra - RacinMasonC
                            Should be fine... I run my 2 step colder plugs all the time.
