heat shield gasket double stack
    I just had the random idea of double stacking two intake manifold heat shield gaskets. Granted longer studs would be needed, I wonder if it would help air temps decrease significantly more than just one??
    discuss...
    My Member's Ride Thread
    i think one will get er done.
      i don't think that extra gasket would really alleviate virtually any heat at all really. not by a substantial amount anyways...
      Yes my name is Dang, Don't use in vain
      1992 Honda Accord EX (Coupe/Bordeaux/Auto)
      1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
      2008 Honda Accord EXL (Coupe/SanMarino/6spd)
        then you are only shielding from something thats supposedly already cool.
        im still a naysayer on bisi's estimate of 7hp on a stock f, and he is yet to prove it.
        honestly, i think it does nothing...but its reuseable which is good by me.
        smoke tires, not drugs.
          using 2 gaskets may cause an air/vacuum leak...
            obviously he would seal it...but still pointless to me.
              i doubt sealing both will prevent it from leaking...or eventually leak...
                I'm currently have one and the intake manifold still stays hot as a firecracker after a long run. The header probably contributes much to that though...
