Has anyone heard of F22 counter measure pistons?
I found some 85mm pistons at work and was told they are a counter measure to eliminate the well known F series piston slap.
Obvious external differences were - A black coating on the skirts - I assume some sort of teflon coating.
And the biggest difference - low dish. Which means they should be higher compression depending on wrist pin height.
I'll have to grab a set next week and see what I find, and post some pics.
Also of note in this thread:
Has anyone fitted F20 Sohc pistons/rods to an F22?
F20 pistons (low dish) were 9.0:1 compression for memory.
F22A1 rods (centre of wrist pin to center of rod journal) are 140mm long.
F20A3 rods (centre of wrist pin to center of rod journal) are 145mm long.
