I just read on some other forum that someone had tried re routing their A/C to blow in their engine bay near their intake for horse power gain. Would that work, or are they crazy?
Re routing A/C for hp gain?
My Cb7. Slow work in progresshttp://www.cb7tuner.com/vbb/showthre...80#post2247580Tags: None
Re rewiring A/C for hp gain!
You can wire a trip switch to detect when you are at wide open throttle, and have that trip switch wired to a relay that disconnects the A/C Compressor Clutch Relay from the ECU while at wide open throttle. So if your A/C happens to be on when you "floor it", you will get an instant load reduction on the motor.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
It's called reach over and turn the a/c off.Originally posted by James Matteu View PostYou can wire a trip switch to detect when you are at wide open throttle, and have that trip switch wired to a relay that disconnects the A/C Compressor Clutch Relay from the ECU while at wide open throttle. So if your A/C happens to be on when you "floor it", you will get an instant load reduction on the motor.
"The Turtle"
DD/Trail Rig/Mud Bug
I figured it wouldn't work. it sounded kinda ghetto. But A/c really does kill my HPMy Cb7. Slow work in progresshttp://www.cb7tuner.com/vbb/showthre...80#post2247580
