Basically i cannot find a good comparison for performance increase per added fuel use for the next step of modifications for my Accord.
It will go faster, and fuel use won't limit how i spend my money.. But i'd really like to know where the best gains are that won't chew the juice.
My engine is modified as follows:
BOMZ short-ram intake w/ Pod
Chipped intake air-temp sensor
4-2-1 stainless header/downpipe
High flow cat
2.5" cat-back exhaust
NGK Iridium plugs
Bosch performance leads
It's the usual, 2.2L F22A9 engine (148-152HP)
And i run it on 95-98 Octane always
From research, my options seem to be as follows..
1. Tune the ECU
2. Machine the cam
3. Injectors/Fuel pressure regulator/Fuel pump
I know all three will increase my fuel consumption, aswell as increasing performance.. Any advice which order to proceed? Or an alternative.. Thanks
High flow cat
NGK Iridium plugs
1. Tune the ECU
2. Machine the cam
