I havent seen this topic touched in a long time. okay theres different ways of making meth injection work for cars.
Theres racegas which you can use ethanol or denatured alcohol with 2 caps of oil from what ive heard which you can make race gas with.
Or you can go and use it through nozzles of an injection kits. most of the time alot of people will use windshield washer fluid the blue kind not the green or the orange. They contain a certain kind of icing agent and propyl glycol which is a certain kind of antifreeze.
You dont want that in the cylinders to get burned off this can ruin your engine. the proper way of making sure that doesnt happen is to not buy that and shake up the antifreeze it must be blue. And it must not contain excessive bubbles which indicate theres alot of deterdents in mix.
When making your own brew you have to make sure you tend to the lines to make sure there are no leaks. And also which i think is really important is to not use tap water.
It contains impurities which will gather and clog the nozzles overtime . Basically hindering the spray patter to evenly distribute the amount of pressure the pump is trying to maintain.
Now as far as the pump and meth mix. Others use 100% meth others use a 50/50 mix which contains half water and half methanol by weight. Geting in more technically the methanol is lighter than water. So you can measure them by volume you have to measure them by weight.
The 50/50 mix is more ideal as it cools the temperatures down its not so easy to ignite as to where methanol heats up when ignited and burns slower.
The 100% meth mix is good for tuners who tune their cars and if not careful it causes strain on the fluid injection pump. It wears away at the seals and the actual pump itself.
It also causes a very rich condition at that and if not careful you can wash away your cylinders,cause and even more rich condition,and a nasty backfire from all that unburnt fuel.
Will fill in more about water/meth injection tommorrow. If anyone wants to throw in more info from what theyve learned about water meth injection please feel free to chime in. Wikked and others
basically the trunkmount which you can tuck away with no issues
