Turbo timer for NA motor?
    so I had a thought today (imagine that), i was wondering if a turbo timer would have any significance on a NA motor as far as a cool down period from hard runs? I would like to hear some input on this please.
    Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
    rock her with the shocker!
    You're not the first, nor last, to come up with this idea.
    Unfortunately the car will definently cool faster when it's off. The car is considerablely hotter sitting and idling, than moving and running, simply because you have no air flow underneath the hood.
    Correct me if I'm wrong fellow cb7tuners.
    Member's Ride Thread
    Originally posted by mercyboy
    I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
      The turbo timer is the cool down the turbo , not the engine
      Accord Of The Month January 09
      Accord Of The Year 09
      My 2 Babys
      BMW TECH FOR 15 YEARS
        im thinking more along the lines of coking similar to a turbo setup as far as the oil sitting there and burning after a hot run. allow the turbo timer to run for a minute or so to allow the oil to run through the motor and cool a little bit before the car is shut down completely?
          That would be cool.
          92 Accord Cb7 ^^
          My Ride Thread~~Click Below.
          http://www.cb7tuner.com/vbb/showthread.php?t=176232
            Doesn't the engine circulate the oil on its own when you turn off the car? Isn't that what the drip drip drip sound is after you run it hard and shut 'er off? These are merely questions, now I'm venturing into the unknown as far as my knowledge. lol
              what your hearing is just oil draining back into the pan, its not actaully circulating through the engine.
                The engine doesn't get hot enough to really have a big coking effect like a turbo does.
                As said above - sitting idling engines get hotter, not cooler.
                Turbo temps are similar to cylinder temps - except the turbo is cast iron which holds that heat, where as the alumimium block and head can dissapate it faster - Not to mention the large coolant surface area around the cylinders as oppose to the small volume in a turbo.
                My 5.7 LS1 Holden Ute
                  Taken from another site:
                  "because n/a cars simply do not generate the same heat that a turbo does, the oil does not sludge when it is left in the galleries upon shutting the engine down, therefore a turbo timer is not necessary."
                  edit: Looks like the guy above me just posted the same thing :@
                    well that takes care of that, lol. thanks for the info on this one, i was curious!
                      I did it regardless
                      I'll need it anyway in a few months, so why not now haha?
                      Nothing better than walking away from your car in a busy carpark with it still running, and have everyone look and ask if you knew you left it on lol
                      Built & Boosted.
                        Of which you reply - "No it's just my NA timer"
                          Haha, never thought to say it that way
                          I've always wanted to walk away and have somone inform me my car is still running at the perfect time
                          So i could wait a few seconds, clap my hands or click my fingers.. And the car would shut off
                          Built & Boosted.
                            Its been done... N/A and turbo timer lol
                            "In normally aspirated cars, the Auto Timer can also be used to warm/cool the inside of the car without having to sit inside"
                            MEMBERS RIDE.
                            Bought from: DannyD , Night Wolf , CB7=91, lummieCB7
                            Sold to: LITuner, rezist09, Pacman91EX, 93AccordLXwhite, PhatAccord, TheNextEpisode
                              ^ Isn't that just a "remote starter" minus the remote and key-less entry?
                              It should be called a pre-turbo timer for those who are going to be installing a turbo in the near future.
                              Been a long time. Still alive...
