Maxbore!!
    Maxbore!!
    I was wondering if anyone has got there TB and Mani done by them, and could you really notice a gain? all in all is it worth the money?
    yea, on a stock f22, it will pull up to 6k.
    also on my most recent f22a6, 131whp with header and cutout as well. however im moving up to the h22 uper plenum.
    I <3 G60.
      Im hoping it matches well with my PnP A6 head..
        honestly, for the 100 dollars you should find a h23/h22 upper plenum.
        I <3 G60.
          Maxbore is a good source for quality and customer service, I have used them.
          Either keep your A6 IM and have it done up or get the H22/H23 upper plenum. Either way those are the better of the common OEM options.
          Hopefully you a camshaft to add to this build.
            yeah im going down to rocklin soon to the picknpull i'll see if they have any h22/23.
            [QUOTE=HondaFan81;Hopefully you a camshaft to add to this build.[/QUOTE]
            saving up for a bisimoto
              Jorge at Maxbore does an excellent job of boring thottlebodies, I've used his services twice and am impressed with his quality and service...
                For what it's worth my K24's stock 62mm throttle body is good for 265whp naturally aspirated, so for $50 or less you should be FINE with a stock Prelude (60mm) or S2000 (62mm) throttle body. The diameter will make more of a difference when you start making a LOT more horsepower.
                I think you'd be better off spending your money on a header, a cam and a tune over the TB alone.
                VTEC G27? = ???whp ???wtq
                VTEC G23 = 220whp 191wtq
                nonVTEC G23 = 200whp 183wtq
                K24 iVTEC hybrid = 260whp 210wtq
                  I agree. Simply do the H23 swap and move on with mods suggested above.
                    I've been looking.
