whats up with bisi gaskets
    everyone keeps naming these in their parts list, why? do they have a performance gain, are they better than oem? is it just for f22's that they are good for h22's also? are they just the new thing or what? please explain. sorry for the dumb questions just trying to not be such a newb, i thought i knew alot about cb7's till i met a guys that was from this site, i found i out i didn't know a shit real quick!
    the one on the intake manifold bisi makes is of heat shielding material. so it lowers the temp of the air coming into the engine. making for a slight performance gain.
    (129)Transactions and counting
      Yea its keeps the heat transfer from the block to the intake manifold down a little bit allowing for a denser air charge which results in HP. A dyno proven around 10 to be exact. Its worth the 48 bones.
        It is a reuseable IM gasket as well.
          i got mine on and now my IM is cool to the touch, even after a long drive
            make sure you keep checking the tightening of the bolts. the phenolic material squishes quite a bit.
              I cant get mine cool to the touch. But it does get VERY hot in SC so it doesnt surprise me.
                ahh. i see. sweet. thank you.
                  Very good point. I had a coolant leak from the IM nuts coming loose on my H23 with this gasket installed and it even leaked into the cylinder.
                  www.PreludePower.com
                  BB SQUAD MEMBER #28 V.2
