I have a h23 upper cai header cat back high flow cat what else can i do to get more power? its a f22a6 btw.
what else can i do...
Aftermarket camshaft, double stack the plenum, test pipe, remove butterflies of not done so yet, port your plenum and iab plats, reduce weight (especially weight mass rotation like AC, power steering, balance shaft belt).
Bisimoto Heat Shielding Intake Gasket
Bisimoto Camshaft, level depending on what you want to do
Bisimoto Camgear
Bisimoto Valvetrain
Boom, one stop shopping for you! We also have access to lightened flywheels as well as more aggressive clutch setups!
Hit me up and I will get you squared away!
Randy@Bisimoto.com
Fuh sho, just shoot me an email! I'll get you squared away!Originally posted by '93CB7Ex View Postnice might get a cam from you guys.
ahh thats why i got bad MPG lolOriginally posted by Sarthos View PostDeleting the emissions won't really help you to add power. It'll just look cleaner but it'll take away some mileage. Removing the EGR might add a *tiny* bit of power, but the charcoal can won't really help.
didnt know if it was a power adder or not but def noticed some throttle response when capping off all the vacuum
only air coming into my motor is through the filter that thing sounds nice when i hit it
