okay so my F22b died on me yesterday. now i'm looking to get a more powerful engine and it's between the H22a and the F20b. i don't have a lot of experience with honda engines, so i need your help. let me know your opinion and why?
H22 Vs. F20b
they are pretty much the same thing...as far as to what i know...
remember, the f20b vtec is OBD2
and h22a (92-95 or 96 to) is OBD1...unless you get the type s 97-01 h22a or h22a4....
the f20b, you have to get the obd1 h22 or h23 dizzy, an OBD1 p13 and OBD1 h22 injectors for your f20b to work....
This has been covered numerous times. If you do some searching you'll find a LOT of results.
To sum it up, the F20B is a destroked H22A Type-S made so Honda could compete is a special racing class for 2.0L and under. Problem is F20B is OBD2 so wiring is different and it's not a direct swap. You have to change some things. H22A is more displacement and has A LOT more aftermarket support. I would go H22A hands down.
Keep in mind both engines use premium gas and a tranny swap I would HIGHLY recommend as your F22B tranny is not geared right for the higher revving H22A or F20B.Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
Yea but how much do u have in your motor? Money wise.Originally posted by fatboy1185 View PostHere's my old F20b setup. On all season tires, slipping clutch, blah blah. 2.3 sixty footer lulz. 192/154 on a poor tune. With sticky tires, would of been in the 13's fo sho. 14.3 @ 99mph with bolt ons.
The F20B has iron sleeves, unlike the H22's FRM sleeves. Personally, I like the FRM, and I've never had oil-burning issues that people tend to associate with them. However, the F20B's iron sleeves are often seen as a positive thing.
The F20B is less common, so you can be "different"... however, it looks like an H22A to most people, and to people that know nothing about these cars, they wouldn't even know it doesn't belong in the CB7! So your "different" status is really among other Accord owners (who aren't all that impressed by it anymore), or among anyone you specifically tell what you have.
The F20B has a higher redline, so you get the fun of revving it to the moon. Of course, it's getting older, and high revs are very hard on an engine... so the older it gets, the greater risk that becomes.
Those are the benefits to the F20B... and even when listing them, I can't help but throw in some "buts"
The downsides are:
It ONLY comes in OBD2... therefore, you will need either a full OBD2 conversion to your car (not happening), a fully tuned ECU, or an H22's P13 (which won't run it properly, but good enough not to damage it.) The OBD2 swaps are a little more complicated than the OBD1 H22A swaps as well. Not bad, but an extra step or two.
It shares many things in common with the H22A, so some parts are easy to find. However, any parts that are F20B specific will be more difficult to find, since we never got that engine in the US. It is unlikely that you could go to Honda and order a part that is unique to the F20B. Now, I don't know which parts these are in particular, or if you'd ever even need to replace such a thing... but it's something to consider.
The F20B comes in two varieties... a 200hp manual version, and a 180hp automatic version. You really can't tell them apart (I believe the difference is in the cams... the manual version has H22A Type S cams, and the auto version has regular H22A cams.) So you'll have to trust whatever importer you buy from, or risk getting the lower powered one.
Honestly, performance-wise they're very VERY similar. The H22A is more well-rounded and more supported. That's what I would go with, personally. Just be sure you get a healthy one.
Not much at all. I/H/E, IM, TB....that's about it.Originally posted by cb7_with_snail View PostYea but how much do u have in your motor? Money wise.
I choose the f20b over h22 anyday.
I have a personal reason as to why. Honestly they are almost the same, and both can be built to the same power output as long as you have funds.
I'm doing something diff with the f20b I'll dyno against a h22 with the same mods and post up sheets when the time comes.
T hopefully things go well when you swap
Wait they will I'll be there lolLast edited by Darkcloud; 06-23-2011, 09:32 PM.
yea man i can't wait to get the swap startedOriginally posted by Darkcloud View PostI goose the f20b over h22 anyday.
Tuesday is payday so things should get moving very soon
about to get my hands dirty!
I've road in both h22 swaped eg hb an a F20b eg coupe bolt on vs bolt on the F20b was faster not by much seemed to keep pulling as where the H didn't.H22 as said has good DD'able low end get up an go an honestly the F20b isn't far off, but still lacking a bit compared to an H.All an all if i had the money i'd go with the F20b, but like i an others have said they are a pretty close match.
02 Crv
