Originally posted by 93Accordian
View Post
H22 Vs. F20b
yah but the part no one tells you is the f20b has the same oil pump as the h22 and it doesnt like revs past 8k and the f20b has people revving it to 9k+. also the f20 does turn kind of high but to really enjoy it you need a b16 trans. always run shorter gears on engines with high rpm power bands and low torque figures because it needs the torque multiplication to get the extra weight moving. if it were me id do an h23a or an obd1 h22 with a f22/h23 crank and aftermarket rods and pistons. then you can move the wristpin higher in the piston and run a longer rod giving you a good rod/stroke ratio to reduce sideloading and torsional vibration but you still get the benefits of the longer stroke.
