so i have a camshaft (F22A6) would a F22a1 Cam gear fit on it or would have to get a F22a6 cam gear for it
camshaft ?
Ah, I was still low on my coffee levels. My brain must have just automatically put 'adjustable' in there, since it's what most people are asking about.Originally posted by deevergote View PostHe's not talking about an adjustable cam gear... just the gear that's on the A1 cam at the moment. I'd say it's a pretty useful item...
Yeah, it comes in handy.
I agree, on a DOHC. On a SOHC, it's just as easy to tweak the ignition timing with the same affect, since the valves will still open the same relative to each other, you're only changing when they open in regard to spark occurence, whereas a DOHC, you can adjust the intake and exhaust sides seperately from each other and relative to spark occurence. They do make for a more performance oriented engine appearance though.
I never thought of it that way!
Well, wouldn't the injector timing also be a consideration? I suppose not quite as much as the ignition timing.
But yeah, since the SOHC cam would change both the intake and exhaust timing to the same degree when adjusted, you're right. Interesting way of looking at it!
DOHC makes much more sense with adjustable gears, since you have control over intake and exhaust independently.
I've had some AEM adjustable cam gears in my basement since 2004...
They've never gone on my H22.
