CNCWerx cylinder support system=block guard done the right way, even though they hate the term block guard. It's a shame they don't do any F or H stuff, not enough demand. You just cannot hammer in an off the shelf block guard against a rough casting and expect the cylinders to not be moved around or ovalized, every single block is alittle bit different.
block guards "good or bad"?
I've read up on the ERL Superdeck System, and all it is based on my reading is Darton Sleeves with a ERL Block Guard welded on top. So in theory, if you've got a good builder you could probably do the same thing much cheaper. But I believe that was the ERL Superdeck I IIRC, the Superdeck II might be an entirely different design.....'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
