outa curiosity what are all your opinions on block guards? and secondly has anyone tried the liquid aluminum block guard? i've heard it done but never heard of any testimony... good or bad
block guards "good or bad"?
They work well. However you should have the block squared up after installing one. Such as a line bore and have a torque plate put on to check for cylinders being out of round. That's the most common problems of installing one. If someone doesn't do those machining processes while the block is apart its power you could be losing. More so on the cyln being out of round. A line bore is just a good idea for a seasoned engine when rebuilding.
liquid aluminum block guards have been done on b and d series blocks and the product used is from a company called DEVCON. my buddy did one for a guy who cracked a sleeve on a previous b16 and the guy never ended up boosting it. its a long drawn process of heating the block up after pouring this liquid epoxy" aluminum" into the deck the drilling out the holes
Aluminum isn't going to warp cast iron easily. The block guards should slid in place rather easily, then be set in place with some epoxy on the block side.Originally posted by deevergote View PostBlock guards warp cylinders. They only brace a portion of the cylinder.
I never heard of the liquid aluminum block guard.
Its crazy cheaper than resleeving. If I would actually resleeve an engine god knows it wouldn't be a f series sohc.
F engines are 300 bucks, pretty cheap to just blow em up
Liquid block guard??? F that.
Block guard simply "close the deck" and when installed correctly will not warp cyln walls. Im not for using them mind you, but the damn things do work. I also prefer resleeve. An H motor that is.Last edited by MortsAccord; 05-04-2012, 01:17 AM.
Its a good alternative to sleeving. Bang for buck is a major plus. Just like stated above though get the proper machining done afterwards. Getting ready to do one on my current project
Ohio CB7's Midwest CB7's Ohioaccords.com
"tellin you dude nacho dick cheese is on the rise! soon it'll be next to spam on shelves!"
92 lx sedan- JY heaven
93 Ex still getn stuff in an out
02 Avalanche
$300 is cheap, yeah... but if you're adding forged internals that could get smashed if the cylinder warps, or a worked head that could get trashed if a piston should get throw into it, and the value goes up considerably. A block guard on an otherwise stock F series would be useless anyway, as the stock sleeves can withstand more boost pressure than the stock pistons can.Originally posted by MortsAccord View PostAluminum isn't going to warp cast iron easily. The block guards should slid in place rather easily, then be set in place with some epoxy on the block side.
To me, using a block guard in any "build" is no better than using a SAFC for tuning. It will work to some extent, but it strikes me as more of a halfassed way of doing things.
youre right but some tuning is better than none. it's a mild modification for a mild build. sleeving is often unnecessary. i think honing with a torque plate is more important which is why my 87mm build is taking so long. i could just spend 500 and get a torque plate that ill use maybe once.Originally posted by deevergote View Post$300 is cheap, yeah... but if you're adding forged internals that could get smashed if the cylinder warps, or a worked head that could get trashed if a piston should get throw into it, and the value goes up considerably. A block guard on an otherwise stock F series would be useless anyway, as the stock sleeves can withstand more boost pressure than the stock pistons can.
