Does anyone make a one piece header for our cars? Please help me out. I am wanting one for tnt_moms car.
One piece header?!?!
"you can catch me swoopin 4G coupin switchin lanes" haha haha.
1993 SE coupe drag car ahoy!
1992 EX coupe 5 spd **sold
Did work for: jhoff_cb7
Traded with: 1990AccordEX,pr3pg4lyfeTags: None
wut do you need one peice for?People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
Is it just no one makes them for accord? What makes them so much harder to install on an accord then a civic? I see them for civic's Teg's but it seems everyone views the one-piece on the cb7 as *impossible* Why???Automotive Service and Fabrication In SOCAL!! https://www.facebook.com/JLRFAB
it WOULD NOT be hard whatsoever to install a 1 piece header on the CB.
The reason I want a 4-1 is because they flow better and ALL 2 piece headers I have owned always start leaking at the joint between the upper and lower pieces. They also sound better."you can catch me swoopin 4G coupin switchin lanes" haha haha.
hmm maybe ur mounts are going bad or are bad causing too much engine movement for the 4-2-1 header, furthermore causing exhaust leakage at the joint. make sure ur mounts are good to go and you can use some lock-tite on the bolts/nuts...you should be fine with that.F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
My mounts are perfect (urethane mounts) the 4-2-1 just SUX. If i have to use one then whatever I will use it till I can get a guy from around me to fab me one up. But I just wanted to know if there IS one for our cars."you can catch me swoopin 4G coupin switchin lanes" haha haha.
correct me if im wrong but i DONT believe there is a company out there that makes a 4-1 style header for our accords....this im pretty certain cuz i was recently interested in one for the sake of freeing up more horses at the high end!
but hey 4-2-1 works just fine and draws out lower-mid range hp. Use lock-tite on ur bolts/nuts on ur 4-2-1.....the new DC sports headers that are 4-2-1 have those O-rings where you bolt together the 4-2-1 to help with the leakage....
Civics have about a foot of extra space between the header and the radiator.Originally posted by Laguna7Is it just no one makes them for accord? What makes them so much harder to install on an accord then a civic? I see them for civic's Teg's but it seems everyone views the one-piece on the cb7 as *impossible* Why???
