Delta regrinds
    Originally posted by midnite racer x
    the zigenballz guy i think had his snap...he's the one with the big smiley face attached to a pole as his avatar i believe
    My timing belt snapped...not the cam...
    the cam would have been fine if it wasn't for the weak ass soft aluminum adj cam gear not fitting the key perfectly...and even then it's not as badly damaged as the cam gear... it's just the woodruff key slot...
    RIP Lifsatrip7
      Someone DID snap a cam on here though...
        Believe it or not, the f series engines in general have problems with breaking stock cams. Generally they break around the woodruff key hole. But it probably only happens to like 1 in 10000.
        12.5 at 114.6mph 15psi
        11.7 and 11.5 20.5psi
        F22a1
        60-1 td06h turbo
        Darton mid sleeves
        85.5 wiseco 8.8:1 forged pistons
        Crower pro billet rods
        Custom ported head.
        KMS valves
        F23 headgasket
        ARP H23 headstuds
        H23 upper intake manifold
        F22a6 lower intake manifold
        Intake manifold is gutted
        AEM EMS 1040u
        FIC 850cc injectors
        Walbro 255 pump
        H23 manual trans
        Prelude shifter assembly
        Forbidden short throw
        Nitrous Express Kit installed, never used on this motor
