msd wire
    msd wire
    is a set of msd spark plug wire gunna help me out at all or no?
    Check Out My Car
    it did to me see my pic.....
    Accord Of The Month January 09
    Accord Of The Year 09
    My 2 Babys
    BMW TECH FOR 15 YEARS
      so it did give u some power gains?
      Check Out My Car
        if u get the superconductor wires OMG def helps u out...not a huge difference in power gain but def better idle, better accel, better fuel economy. if u go with the basic msd wire....very little difference. hope this helps!
        My members ride thread
          yes but i got MSD coil, wires,cap and rotor. when i use the nitrous... feels much better... i going to get the MSD 6AL in 3 more weeks
          My 2 Babys
            That also means you are using the MSD 0.8 ohm resistor...Although the Honda stock ignition is high powered, the MSD can free up existing horsepower in the top end. Its a great improvement, plus all the characteistics of the car are smoother.
              what resistor
              My 2 Babys
                what resistor
                I hope your voltage is not jumping all over the place then. MSD makes a Ballast resistor for people who want to run the coil alone. Basically it keeps the voltage in line so your turning signal doesnt just go off, or you brake lights flashing nonstop. (happenned to me before i got it). It is necessary when running coils like the blaster ss, 2 and 3 in our CB's. Unless your car has no electrical problem so far...how long you have been running the coil?
                  so http://www.prostreetonline.com/buy/m...g_wires/honda/ is what i need and that will help me?
                  Check Out My Car
                    it's been in the car for 4 month now.... no prolem found at this time...here the pic...
                    My 2 Babys
                      are the wires for the lx wagon and my lx sedan the same 2.2L? i didnt see one that said 2.2L LX sedan.
                      take a look
                      Check Out My Car
                        take a look
                        Yo the EX wires will work on your car
                        My 2 Babys
                          i went ahead and ordered the wires for the wagon but i was looking and the part number for that and the ex are all the same so it doesnt matter. i am ordering a ss blaster coil and hi per. distributor cap as well. thanks guys!
                          Check Out My Car
                            Damn, my car really was one of the few cars that got screwed. I ran a Blaster 2 coil and the voltage would do things like make by brake light come on, turning signals, you name it. I installed the resistor and it took a while but everything went back to normal.
                              hope my car doesnt do that, i am using the SS coil
                              Check Out My Car
