is a set of msd spark plug wire gunna help me out at all or no?
msd wire
it did to me see my pic.....
yes but i got MSD coil, wires,cap and rotor. when i use the nitrous... feels much better... i going to get the MSD 6AL in 3 more weeksOriginally posted by xtr91accordso it did give u some power gains?Last edited by RICHIE*GT35R; 07-30-2005, 05:57 PM.
That also means you are using the MSD 0.8 ohm resistor...Although the Honda stock ignition is high powered, the MSD can free up existing horsepower in the top end. Its a great improvement, plus all the characteistics of the car are smoother.Originally posted by RICHIE*NITROUSyes but i got MSD coil, wires,cap and rotor. when i use the nitrous... feels much better... i going to get the MSD 6AL in 3 more weeksLast edited by KillerCam282; 07-30-2005, 06:12 PM.
what resistorOriginally posted by AcclipseH23That also means you are using the MSD 0.8 ohm resistor...
I hope your voltage is not jumping all over the place then. MSD makes a Ballast resistor for people who want to run the coil alone. Basically it keeps the voltage in line so your turning signal doesnt just go off, or you brake lights flashing nonstop. (happenned to me before i got it). It is necessary when running coils like the blaster ss, 2 and 3 in our CB's. Unless your car has no electrical problem so far...how long you have been running the coil?Originally posted by RICHIE*NITROUSwhat resistor
so http://www.prostreetonline.com/buy/m...g_wires/honda/ is what i need and that will help me?
it's been in the car for 4 month now.... no prolem found at this time...here the pic...Originally posted by AcclipseH23I hope your voltage is not jumping all over the place then. MSD makes a Ballast resistor for people who want to run the coil alone. Basically it keeps the voltage in line so your turning signal doesnt just go off, or you brake lights flashing nonstop. (happenned to me before i got it). It is necessary when running coils like the blaster ss, 2 and 3 in our CB's. Unless your car has no electrical problem so far...how long you have been running the coil?
are the wires for the lx wagon and my lx sedan the same 2.2L? i didnt see one that said 2.2L LX sedan.
take a look
Yo the EX wires will work on your carOriginally posted by xtr91accordare the wires for the lx wagon and my lx sedan the same 2.2L? i didnt see one that said 2.2L LX sedan.
take a look
