Just letting peeps know, as I get closer to a running engine on my white 91 EX F22 all-motor build, I'll be working with MRX in tuning it. It should be fun seeing I have more than must bolt-ons. We'll see what happens.
Calling N/A f22 people looking into chipped ecus
Originally posted by hatchninjahey, we've been communicating via e-mail. patrick_kerce@columbia.sc. Hopefully we'll have motor with enough cam and compression to justify some ecu tuning. Don't give up on it yet guys. look for a budget n/a writeup before next summer.Knowledge is power...in EVERY sense of the word
Hey, Midnight.... Can you help out those people W/H22 na & Bolt-ons? I feel I have enough mods done to my motor to warrant some good tuning. Let Me Know..Automotive Service and Fabrication In SOCAL!! https://www.facebook.com/JLRFAB
Originally posted by alb_accordme and a friend of mine are going to mill the a6 head .45 and port polish and some cam work.....
now what are some of the compresion numbers that an engine should have in order to see some gains from the chipped ecm?
With that much of a mill...What will your compression be?92 DA9 // 93 D21 4x4 // 92 CB7
it should be 9.6....just use a b-series compression calculator and change all of the specs to f22 specs. .060 would get you 9.97.....no one really knows what the clearances are since no one does this, but pretty much everyone agrees that it's not a good idea in case you warp the head and need to have it milled again to straighten it out. But who cares.....lot's of b/d series guys do it. I'm one of them.
edit......i'm thehatchninja....keith always logs in on my computer and forgets to log out.Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
Type S pistons and cams
New Ride:
Bone stock 99 2.3CL
Black on Black Leather
5spd
"Experience: that most brutal of teachers. But you learn, my God do you learn."
C. S. Lewis
we have been told that it will be more than 9.6... but no one is giving us a straing answer.
for now all i am sure is that if u mill the head pass .55 then u are in uncharted territory. there was a thread here in cb7tuner about 1 year ago about milling the head but i can't find it.
but with milling the head, delta cam,, h23 intake system and bored throttle body and a nice exaust i belive that we can put the chipped ecu into good work. but thats me. we are also considering swaping the head with the head of a 96-97 accord ex and see if we can get better air flow.are we there yet are we there yet are we there yet
almost doing the same set up to my cb7 (see sig) .050" will bump compression up to around 9.8:1 (according to the B series calculator with F22 specs). With milling, 272 grind, intake, header, exhaust, bored IM/TB, we will definately need tunning to get the optimum power from it.Former Ride:
93 Accord Coupe
Jdm H22 w/ LSD
New Ride:
Bone stock 99 2.3CL
5spd
C. S. Lewis
Originally posted by hatchninjayou won't get better air flow. F22A heads have the best port geometry of any f-series.
wordFormer Ride:
93 Accord Coupe
Jdm H22 w/ LSD
New Ride:
Bone stock 99 2.3CL
5spd
C. S. Lewis
yeah i have been searching around honda-tech. accordinglydone and some other sites and most people tend to agree that f22a engine have better air flow.
so now we might go with a dohc head and see what kind of gains does it have to offer,, and see if it worth the money, time....are we there yet are we there yet are we there yet
