well i wouldnt try that. but i have seen CO2 kits.... sposed to make the air going into the engine a lot cooler, and of course making more power, yada yada yada... do that instead.
Oxygen boost?
pure oxygen is a bad idea you wouldnt just blow up your motor, the person inside the car or around the engine bay would most likely not survive an explosion like that pure oxygen is extremely combustable and would probably turn your car inside out when you hit the button. nitrousoxide works well because it carries the oxygen and nitrogen which acts as an inhibitor to the combustion it effectively slowes down the combustion process, pure oxygen would speed up combustion and make a geat big boomH22a swap
18 speaker audio system
Tokico Illumina susp. kit
Motegi FF5 17`s
VIS racing CF Techno R spoiler
not saying that your saying this, but to kill it before it gets life. co2 is a byproduct of used 0xygen and inject it in to engine would make is cut off. but i know the kit you speak of.well i wouldnt try that. but i have seen CO2 kits.... sposed to make the air going into the engine a lot cooler, and of course making more power, yada yada yada... do that instead.
