t3/t4 on 2g manifold? Tired of Searching.
    I tired of searching. Will a t3/t4 mount up to a 2g manifold? If not, what do I need to make it work?
    yes u can.. use an adapter plate..
    www.bmcrace.com
    dsm/ t3/t4 adapter plate..
    this is the one to look for
    "T3 (Standard) to
    14B (1&2G DSM)"
    Praise The Lowered...
      Thank You!
        no problem mang... lol.. i bet i just saved ur ass from having to buy some *** ass dsm manifold flanged for t3/t4 off ebay.. ey???
        10 bucks says.. now ur gonna get urself a good dsm manifold.. with no cracks.. and slap on some t3/t4... hehehe..
          Also:
          hahnracecraft.com caries it. Might be cheaper.
            Hahn's adapter is more expensive, I've checked on their prices and ended up buying from BMC
            1993 Prelude S
            F22A1
            custom'ish turbo setup
            180 whp/217 ft-lbs super hot, super humid, super rich, boost falling off at 8psi
            18psi boost spike = BOOM!!!!!
            currently being rebuilt
              Kick ass. So to confirm, I buy myself the 2g Manifold and the Flange and I am good to go.
                correcto mundo.. then itll just be a matter of how much more out of the block ull have to chisel out.. lol.. since the flange is gonna make the turbo sit lower.. ull probably have to remove a bigger chunk.. to clear it..
                  you definately need to grind a crap load with that adapter, trust me i know. i had to grid so much thati made holes going to the transmission housing. i would suggest dont be a cheeap juu(like me) and buy at least a log manifold that doesnt require you to grind the hell out of your block. OR buy a t3/t4 with a dsm housing already one it like a bullseye turbo
                    what if he angle cut the flange.. at an angle so that when bolted to the manifold.. it would cawk the turbo towards the front of the car..
                      http://www.tt3kgt.com/friendpics/ray...e/manifold.jpg
                      like so... i know the adapter plate isnt as big.. but what if u grinded it down about 1/4 unevenly.. cut at an angle basiclly.. that way when mounted it would make the turbo sit further away from the block.. (less grinding)
                        thats a good idea...
