Im kind of new to this but I am looking to get a larger camshaft...if you could please look at my mod specs in my profile and let me know what i should go with. also where would i be able to purchase it. Thanks!
camshaft question
you honestly dont need a cam.....yet
1)-10.3 mm wires dont mean anything-go with oe set of ngk or 8mm accell or equivalent.
2)-junk the bosch platinum 4's and pick-up ngk plug or ngk iridium plugs. oe and stock is better.
3)-teach yourself to drive manual then swap the tranny to manual.
4)-your build doesnt require a new cam yet. you should yank the head off at least and get a port job. someone on here can sell you a reground cam or look online. f22parts.com sells a nice set of upgraded valve springs for wwhat i know was 149.99 you may find cheaper online else where.
5)- basically at this point you should worry about upgrading you fuel and ignitoin 1st. before worring about messing with the head.
goodluck your off to a great start though.
regards x
