ive used redline in my f tranny and loved itbut my friends all use GM! well i have a new accord with stock fluid and would like to change it out. what are your experiences or stories? or suggestions!
syncromesh or redline
Royal Purple has a product called Synchromax. I used it in my Galant VR-4 (which have JUNK synchros) and it shifts better than it did with Redline MTL.
Synchromax is specifically designed for transmissions that use motor oil for a lubricant (like a Honda!).
I'm going to put some in the next time I service the car.
edit: Make sure you don't buy the stuff they call MaxGear. That's what I SHOULD have put in the Galant. MaxGear is 75w90 synthetic, not for Honda trannies.
..since we are on the topic of trannies, anyone wanna tell me what's going on wit mine? There are times when it does'nt wanna shift into 2nd, or 1st. It shifts into the other gears just fine, but then i go to secon,d and it is almost like it doesn't exist. like the area it shifts into is not even there. To fix it, i gotta slam the clutch down, through the floorboard. Sometimes it happens, others it doesn't.. i know it's not fluid..i just bleed my clutch at work. I wanna figure out what it is..does the clutch linkage need ot be adjusted? is a syncro bad? I would think that part no, since first gear doesn't have a syncro..any ideas?
-A. SwiftCB7 member number 137
Black Doubt Crew member #2
Ebay Whore Club member #5
-I was at the dentist, breathin' in some nitrous oxide (laughing gas) and all of a sudden..I ran faster!!!
AIM: boostinswifty38
alipne 7995 deck, pioneer 400w 4 ch amp, and all the wires for sale..500 obo!
R/C cars and a heli for sale..2 airbrushes, paints, bodies galore..etc etc..tc3 and xxx buggy for sale..400 for it all! hit me up for details n pics
Okay heres tha deal you may have to change your slave cylinder for the clutch or the clutch master cylinder or both . But try to adjust it if you know how to first before you buy the stuff.
If you look under the dash where that line is on the pedal its than thin metal bar that goes through the firewall from inside of the car theres a little rubber seal if its wet or spits out little bubbles you may need a clutch master cylinder .
..from right behind the pedal? Wouldn't a new cylinder mean that there is a problem wit all the gears? I am only getting the problem with 1st or second..that's why i would think it's a linkage or syncro problem..
