A4 header question
    A4 header question
    So if i get an a4 should i only get the top part jsut the header or should i get the whole downpipe....i've searched...
    you must get both thing at the header is 4-2-1 where as the other one is 4-1
    Members Ride
      So... you have an F22a1 stock header and downpipe? Well, it is good that you are asking, because I found this out the hard way- I bought the header and now I am trying to come up with a downpipe.
      So: the flanges from the F22a1 downpipe will not attach to the F22A4 downpipe. Furthermore, the F22a4 and F22a6 have the O2 bung in the downpipe, which is more efficient, so you DEFINETLY need to buy an a4 or a6 downpipe. Whether or not the a4 fits on the a6, I do not know.
      Why? Because... Life Happens @ 4500 RPM
      Frost White CB7 Member 31
        The a4 is a pretty much stand alone type thing. I've looked at other accords in junkyards and i can say a4 exhaust mani-a4 downpipe that's it. Can't be worked any other way. maybe a1/a6 stuff but wtf cares about that?
        Horsepower sells cars, torque wins races.
          Get the whole header/downpipe assembly.
          Always remember that only you can make your dreams a reality.
          Never forget that your style is all that matters when it comes to your ride, but be respectful to others who don't share your vision.
          Proud Alum of the University of Texas at Tyler, Class of 2010
            I would pluck the whole thing to be safe.
            The A4 and A6 are both 4-2-1.
            The basic design of the A4 and A6 downpipe is EXACTLY the same, but there seems to be 2 different bolt patterns. Some people have tried to mate an A4 upper with an A6 lower and the bolt pattern was different.
            I have seen an A4 upper bolted to an A6 lower, which would indicate there are multiple bolt patterns.
            The way to avoid that is to just get the whole thing together. Then you KNOW it will work.
              another question this might sound stupid but what if i get the a4 and get ceramic coat paint and put it on them along with the heat shield/? should that ceramic outter coating help or no ?
                downpipe is a word used to describe the piping that goes from the exhaust port of the turbo to the exhaust
                on na applications its (starting from) headers-->a-pipe-->cc-->b-pipe-->muffler or axel back whatever you want to call
